'95 ZR-1 Gross Weight?
95ZR1#418
Missoula, Montana USA
95ZR1#418, 88Z51Coupe, 69L46Coupe
Hi All-
I seem to have difficulty finding what the gross weight of a ZR-1 is by using the searches. Wondering for trailer hauling specs, anyone know?? around 3400lbs? :eyerole
TIA
The gross vehicle weight should be on the sticker inside the drivers door frame.
:w
Hi All-
TIA
As stated earlier the car's GVW is listed on the door pillar.
You'll be surprised how little the car's payload actually is. "Payload" is GVW - the curb weight and is the weight of the occupants and any cargo.
A ZR1 is not intended for trailer towing...certainly not one weighing 3400 lbs.
:duhI think you misread that Hib. I'm sure he was wondering as far as load on the trailer. NOT hauling a 3400 lb trailer. :chuckle:crazy
:w
:pat
:w
Thanks for that info. O.K., so the GVWR = 3962lbs per the door sticker. Also on that sticker it says Vehicle capacity weight = 399lbs. So does this mean 3962-399=3563lbs which is the actual cars empty weight? The weight of it which will be set upon a trailer?
GVWR is the vehicle, full of fluids (including gas), and IIRC two passengers at an estimated weight of ~160. Can't remember for sure if the passenger weight is correct, actually I can't remember if it includes driver and passenger.:confused But yes your math is correct, although the empty weight does include a full tank of gas. I estimate mine at 3500 lbs for towing purposes. With the weight of the trailer I'm pulling somewhere around 5000 lbs. Easy money for my Silverado SS. :upthumbs
You could load up and go to a certified weight scale and have them weigh your trailer for you, if you really want to be exact. Most truck stops have them. Might cost you $10 or $15.
:w
:pat
