'96 LT1 fuel relay
  • Thread starter Thread starter DMGroh
D
DMGroh
Need some help locating and identifying relays; specifically the fuel relay. Both manuals indicate it is on/near firewall passenger side. Only thing close in engine compartment are 3 large relays (2 black on outside/middle, gray near engine), and 4 small relays under passenger dash-1 identified as fog light. Can anyone tell me location of fuel relay, as well as identify each of these mentioned relays?
Relays
Welcome to CAC. It's really helped me several times.
I have a '95; yours may be the same (but be cautious).
Do you have an automatic or 'stick'?
Do you have 'manual' or climate control A/C?
What is the difficulty that you're having?
If you have 3 relays on the right front wheel-well, you probably have an automatic with 'manual' a/c. If that's true, the three relays on the right front wheel well are for the A/C compressor clutch, the Blower (low) and the Blower (high) starting from the engine and going out.
The fuel relays are in a 'relay retainer' under the passenger side of the instrument panel; relay A is the horn, relay B is the fuel pump #1, relay C is fuel pump #2, relay D if the fog LP, relay E is the courtesy LP.
I haven't found the diagnostic diagram yet but will try to locate it.
If your fuel pump isn't running, it could be the pump itself or the oil pressure switch (near the rear, upper center of the engine at the back of the intake manifold).
Hope this helps
