OK 88 vette here goes , it seems that the blend doors are not operating. There is no vaccumn leaks pulled a vaccumn from the firewall into the car with a gauge on it and it held steady. Pulled a vaccumn on canister and vaccumn lines under the hood and it held steady. Checked engine vaccumn and it was about 18- 20 at the engine. I have the dash half apart noticed that while switching the system around nothing really happends. It seems to blow out the center ducts always no matter weather i bring the heat on or cool on. The defroster door doesn't move at all no matter what i do. Air is also coming out of the defroster the door is in a halfway open state. I can move the defroster door into the closed position with my hand but it goes back into the split position where the air comes out the center ducts and defroster vent. The heat cool control work ok because it goes hot to cool but only comes out the center ducts and defroster vent. Remember there is no vaccumn leaks that i can see.
