anniegreensprings
I have a 1992 Coupe. i replaced the compressor, receiver dryer and condenser. it's been retrofitted for R134A i had the system vacuumed and checked for leaks, and was good to be re-charged. the problem i'm having is that when i make the system call for A/C cooling, say 22 degrees celcius, it blows a little cool air but not like it use to. some times it well blow a little warm air for a few seconds and then a little cool air.
this does it when you run it on the manual way and even when you run it on auto. when you turn it down really low and run the system on recirculate it gets quite cool for a bit but then it starts to blow a little bit warmer. when you call for cool air, shouldn't the clutch on the compressor cut in and stay engaged. i think it's in one of the switches , but i'm not sure if it's in the cycling one or refridgerant pressure sensor switch or compessor engine coolant temperature switch. now i am running a 160 thermostat. stock is a 180. could this be creating the problem. if anyone, who has a good background in A/C systems could help me out i'll leave them a little somthing in my will.
just point me in the right direction, thank you for your time.
