A/C Turn on Question
  • Thread starter Thread starter CAJUN C4
C
CAJUN C4
On my 95', with the fully automatic system,I had a strange thing happened last night.I pushed the A/C on button and nothing.pushed Fan only..nothing.Then after about 15 Min. it came on.Thought it might be a relay problem.I checked the FSM and it looks like there in't a Blower Relay.Pg. 1B-25 says VIN P C68 (A/C Programmer) Man. Trans. only has an A/C Clutch Relay and an 2nd & 3rd Gear Blockout Relay????? This morning same thing.but I did leave it in the on position and after I hit a rather large bump it came on Again thinking relay being jarred loose,. Now today it's still working after cycling it on & Off a few times.
Now I'm really confused.I wonder if the Programmer does all this.
Any ideas as to where to start looking?
Thanx
(snip)
Thanx
Since you hit a bump, and it came on, I'd start looking for loose connections in the wiring having to do with the blower motor and the control head.
Fixed..The Blower Motor was Bad.Tapped on it and it started right up. I should learn to check the simplest things first and not make assumptions.
Thanx Guys
