A/C vac leak, common areas?
Tallahassee, FL
none right now :(
I have a problem with my A/C... when I hit the gas, the air blows to the defrost.... I assume vac leak... the question is, where do I start looking? is there a most common area(s) to look at first? thanks!
There should be a check valve at the back of the intake. Start there, the Check Valve controls Vacuum to the AC and Cruise.
Thanks, the cruise control works though... (I am actually posting this AC problem for a friend with a 1995 and should say His cruise control works, and AC doesn't work)
vettelt
i had thisproblem with my trans am once, sounds alot like your friends when passing someone or just getting over about 1/2 throttle the a/c would switch immediately from the vents to the defroster turn out to be the vacuum resevoir ( ball ) had a crack in it after GM replaced it a/c never did it again
