GTR1999
Looks like a 70's posi. Yes it is better then your DANA.
I would take it apart, I can see it has the slotted " snowflake" clutches in it, appears to have 10-17 spiders as well. My recommendation- polish and tune it. Once apart spray it down with brake cleaner and likely blow it off with air. Any cracks will show up still wet. If you find any cracks the case is all done. The marks are from the pinion, those can be polished out no problem. I would install solid steels, a new cross shaft, and mill the pad 120" deeper- that is how I do all mine.
If you are going to reuse the 308's radius the edge of the teeth, an old hot rodders trick and helps with mesh.
