J
jmp
As a preamble, let me just note that this conversation actually started off in BHP Explanation..., but since I was getting off track, I decided to start a new topic here. Check the link above for the beginning of this discussion on AIR and LT-1s!
Now, without fdurther ado....
I'm slightly po'd!
OK, let's get the minor things out of the way first.... I don't have the tire pressure sticker. I don't have the Canada export sticker. The car was imported into Canada, though, in August of '71. I have two copies of a GM Canada, dated April 28, 1998, that has my VIN number on it along with the option list, production date, shipping date, etc.
The option list includes L08 (Engine Emmission Certification), Z49 (Mandatory Canadian base equipment modifications), and ZK8 (Tire Pressure Sticker). Can anybody give me details on this?
Oh, btw, the doc also says atha only 1058 'vettes, 131 of them being LT-1s, were produced for sale in Canada.
OK... I looked at the emmissions sticker and it doesn't say anything terribly informative. Tom73, I'm not sure what you thought it might say that would help...
On to AIR. First, I looked up the exhaust manifold #s in my Restoration Guide and it gives two different #s for LT-1 exhaust manifolds in 1972:
3932461 for left and right
386711 for left and right
Second, I looked up the engine codes:
CKY: LT1 with Holley four-barrel, mechanical lifters, and four speed (my car, btw)
CRT: LT1 with Holley four-barrel, mechanical lifters, K19, and four speed.
Now this seems to contradict another portion of the book which states that all LT-1s in 70-72 were originally AIR equipped.
Third, I pulled the numbers from my exhaust manifolds. Both right and left say 3932461. I looked for the holes for the AIR fittings on the right-side manifold, but didn't find any -- they're not there. Just for fun, though, I took a anotherlook at the left manifold too. At first I thought that the holes for the fittings weren't on that manifold either, but when I looked closer I realized that the holes were there -- they were just plugged!
It appears as though this engine has gone through a significant rebuild sometime in the past -- maybe when the block was cracked!
But when it was put back together, somebody got left and right mixed up: the exhaust manifolds and the valve covers are both mixed up!
Well, I'm still not sure. The manifolds look like they should have an AIR system attached, but my Restoration Guide says that the CRT engine and not the CKY engine had K19 (A.I.R.). Hmm... thinking about it though, I'm not sure why I think my car is the CKY. As I said, it's a new block, so there is no code stamped onto the block (other than the casting number).
Is there anyother place that the CKY/CRT code would show up?
I'm slightly po'd!
