windrider50
Ok, I'm thinking I'm so far in to this problem that I can't see the forest for the trees. My 72 coupe sat for about 6 years, and as I awoke it, the brakes had disappeared. Translation: pedal went to floor, no braking at all.
Ok, so I rebuilt all 4 calipers, installing VB&P's O ring conversation kit, 4 new rotors (the old ones appeared to be original), and a new mater cylinder from Corvette Central.
Now the pedal goes almost all the way to the floor, and barely holds the car at idle in forward or reverse. The brake warning lamp is functional, but does not illuminate when I press on the pedal, indicating to me that the proportional valve is not an issue. I have not taken it out on the street, as I feel decent brakes are a good thing!
I have bled those puppies by gravity first, then via the pedal approach until NO bubbles appeared, then I went around and tapped on each caliper with a rubber malet to dislodge any trapped bubbles. Then I bled them again and saw little or no bubbles. No leaks apparent anywhere.
Other than the power poster, any ideas? I thought when the booster goes bad, pedal effort increases, which is not I case I find. I will checking the length on the adjustable rod that transmitts the action from the booster to the M/C vs the spec.
Any and all suggestions ( as they relate to my problem) will be greatly appreaciated.
NJ BB Ken
NJ BB Ken
