ABS & ASR warning lights come on at 70 mph
  • Thread starter Thread starter vipereater
V
vipereater
Everytime my 98 reaches 70 mph the ABS and traction control lights come on. Has anyone had the same problem and is there a simple fix?
Vipereater
HI there,
You have a c1232, which is the shorted or open wheel speed sensor, left front.
Also of concern, is the c1255, the c before the number, stands for Chassis. 1255 is for an internal fault of the ABS.TCS module, for the traction control, antilock system.
Now, this is a double edged sword, as you will need to inspect the left front wheel speed sensor harness for an open circuit, when flexed.
The 1255 could be more tricky, and I would suggest that you have your local Corvette specialist check this one out.
Hope this helps, c4c5:hb
