malc350
A while ago I posted a problem with my ABS. When I do the ALDL check on the codes I get a code 31 (right rear sensor fault) and a code 25 (left front sensor fault). The codes appear in that order: 31 first, then 25, is that right?
I checked the reistance of both these sensors. The right rear was slightly out of range (high resistance) so I replaced it but I still get the same codes as well as the service ABS light in the DIC.
I have tested the resistance at the white connector near the ABS modulator and that is near as dammit the same as the resistance at each sensor. I have concluded from this that there is no short in the wires from the sensor to the modulator. Again is that the right conclusion? I'm a bit of a rookie with electrical faults but I'm trying to act logically!
I find it hard to believe that both sensors could fail at the same time (!!!) and the fact that I have replaced the right rear sensor and still have that code (RR fault code 31) makes me think that the fault lies elsewhere. I suspect an earth or some connection somewhere (I'm guessing).
Can anyone suggest a likely cause of both fault codes appearing at the same time? It's not as if they are even close to each other on the connectors. Does anyone know if there is a connector under the dash anywhere? Maybe leading to the DIC or brake pedal. The reason I ask this is that the wiring seems OK from the sensors to the modulator but when I trace some of the wires they disappear under the carpet and run under the sill cover towards the front of the car. I figure there must be a connection somewhere to check?
The only other thing I can think of is that the ABS ECM is detecting faults that aren't there and that the ECM is at fault. Sound expensive.
Thanks for your help in advance.
