PATZ06
New member
Have had a problem with the abs etc light comming on for a few years on an 02 z06. Had the unit checked and diagnosed as ebcm. Had it rebuilt then sent it back because of more codes than original. Second unit gave 1 code indicating passenger side sensor. Tried cable change first with no luck. Just changed bearing assembly with again no luck. Abs etc information clears when car is shut down then restarts at 40 mph on an "docile" acceleration (or equivalent on hard acceleration). Any good ideas?
Pat
Pat
