malc350
My AC compressor on my 90 is not engaging. When I go through the AC diagnostics the only fault code I get is 09 (low freon level detected).
When I took the car to the air con shop the guy connected my car up and said my car is holding pressure but the AC compressor clutch is not engaging - that's why my air isn't working.
I have a feeling there's nothing wrong with my AC, - it just needs gas (?) The mechanic said I could bypass my pressure switch but as far as I can see I have three pressure switches on my AC lines so which would I bypass?
The AC hasn't worked as long as I've owned the car - just over a year (I know I should have attended to this earlier) - but I'm sure I've seen the compressor engage before. The clutch isn't seized because I can turn it by hand.
Any help would be appreciated. Thanks, Malc.
