ok, this one has me boggled......
when I got my '78 (L82 with AC) the end of Feb and had it flatbedded home the first thing I did was go out and buy a new battery - the car didn't have one at all.
It sat untouched for about 2 months while i pulled the motor, cleaned and refinished everything than put the motor back in.
since I got the car running the battery has gone dead 5 or 6 times.
Ok, I figure it's one of two problems:
1. charging system not working correctly
2. a drain somewhere in the system.
I checked the charging system and it's fine. Good output from the alternator and good voltage back at the battery to charge it. No problem there.
That leaves a system drain ( of course, the HARD one to deal with - it can never be easy like the alt isn't working and i can have that swapped out in 10 minutes!)
I didn't get a chance to check thru the system to try to find the drain before taking the car into the paint shop (where the battery has already died 2 or 3 times in the 3 weeks it's been there!).
Wet to check on the car today and the painter tells me he thinks he found the battery drain issue purley by chance.
He had been sitting in the car, the shop was very quiet and he hears a very faint whirling sound. Turns out it was the climate control blower fan running slowly. The problem is the car was off and the key was out of the ignition!!
Moving the fan speed selection switch didn't make a different but he found that the top slide controle (the one that selects MAX AC, AC, HEAT, etc) had to be moved all the way to the left to the OFF position to get the blower fan to shut down.
WHY would the blower fan possibly be running with the car off??
This has to be the drain on the system that is killing my battery but I'm not even sure how to go about fixing something that I can't figure out how it could be broken. But broken it must be as the blower fan shouldn't be running with the car off, let alone with the key out of the ignition switch.
Maybe a relay gone bad and shorted out to show constant live power innstead of switched power on the blower??
) that if the blower operates with ignition off it's a malfunctioning ?? blower relay (closed contacts)
