kirkeric
Hello,
I have another thread titled "Removing Dash from 1987 Coupe" but the underlying issue is AC and presume that is why I've gotten some limited responses from our good man Jester.
I have an AC problem that was originally diagnosed as leaking o-rings on compressor, bad wiring connecter (fixed) that was prevently compressor from kicking in, and bad evaporator core.
The leak is minor since it began blowing cool air once I fixed the wiring problem (just replaced connector pins).
My problem is the fan blows very low, even on high. Jester asked some good questions that I will summarize here.
Fan speeds are noticable between lo, med, high.
Fan works the same way even in heat mode.
All functions, such as bi-level, defrost, etc work.
The only issue seems to be that the fan just doesn't blow well enough.
I am not convinced that the evaporator core is bad since I DO have cold air, just not enough.
My assumption at this point is that the blower needs to be replaced.
I appreciate any feedback that might help, to include how to do the replacement. That was the original reason for the other subject title was that I know I need to remove the dash to replace the blower and or the evaporator.
I thank you all ahead and thank you jester for your assistance.
Eric
Eric
