Accelerator Bracket
Mike Carter
TEXAS
1972 Targa Blue Coupe, 1991 Black Roadster
I'm looking for the LT1 Accelerator Bracket for a Holley. Different than the QJet bracket. It mounts at left rear of carb, holds acceletrator cable, return spring and brake vacuum, any help would be appreciated.
Mike
hehe....and if someone has 2, I'll take the second one. I 'recycled' my bracket from my q-jet, and the throttle linkage has a lot to be desired.
-Vic
I'm checking with the suppliers, Corvette Cetral lists a part # but no availability, most others do not list, I'm calling Dr. rebuild today, I'll let you know.
Vic/Tom,
Doc has them, I ordered PN 3459210 Bracket, 3425199 Clamp and 3425225 Bolt, total came to 54.85 w/shipping. The bracket alone was 30 bucks. It may be a little different than stock, but they indicated it would work fine.
Thanks for your help.
Mike
thanks. but yikes!! 54 bucks! I'm gonna look real hard at that piece. I may be able to fabricate a bracket myself.
-Vic
Vic,
The bracket is around 30, there was over 8 bucks in shipping.
Mike
Thanks for the pricing and part numbers, Mike. I really could use that bracket. I'll most likely just fork over the bucks to get it. It'll have to wait till after the holidays tho.
I will get that vaccuum fitting this week. I also need to get a steering column part and some window parts.
-Vic
i think I got my vacuum fitting, brake booster line, choke coil and rod, fuel line and fuel pump from Corvette Central, I may have had to go to Ecklers for some of it. Anyway it's all right stuff now except that darn bracket. Good luck and Merry Xmas .
Mike
