srvett
- Joined
- Oct 4, 2002
- Messages
- 17
- Location
- Central Indiana
- Corvette
- 2003 Z06 98 vert 88 Callaway TT 78 Pacer L-82 4spd
Help! My 1988 Callaway has a problem. The lower banjo fitting on the oil pump drags against the water pump pulley when the AC is on. I tried changing the belt but with no success. It looks OK when installed and works OK until you turn on the AC. Then the oil pump drags hard against the water pump pulley. The cross referenced belt is 92.3" long. I tried a 91 and a 91.5 but could not get them on even with the alternator loose. Is the Callaway belt different than the stock belt? I assume this is a belt size problem but could it be something else? Could it be a problem with the oil pump/tensioner?
