Accu-Bra for C5 installation question
Greg C
Ann Arbor Michigan
2000 Convertible;Bowling Green Metalic
Have purchased a Accu-Bra from Ecklers. Installion guide says it is manufactured for GM.
Two questions;
1; the top "fold tab" that fits behind the front edge of the wheel well. This tab is supposed to hook around soemthing and there is no "open" space for it to fit into. What do you do here?
2: The 2 "snap studs" that are supposed to replace the factory screws inside both wheel wells do not fit or hold very tight. They do not have the same threads as the factory screws so you just can't screw them in. I have ordered snap studs from a vender in texas (Mr. G's). What did you do here?
If it is anything like my gm bra you have to remove the factory screws and the clips they screw into then you should have rubber inserts that your machined bra screws will fit.
The folding tab does not fit into anything it justs hooks around the wheel well.
