- Thread starter
- #21
M
MacShee98
Thanks Andrew!
That's Sony is an interesting concept and I'm sure we'll be seeing built-in hard-disks in head units now that Sony's taken the lead.
Unfortunately, it doesn't solve the problem of adding an MP3 player, or another type of aux audio unit, to the existing factory setup. I'm sure that there are some people who would prefer to leave the factory player AS IS and not mess with tearing the radio out and figuring out how to fit a single DIN unit into a 2 DIN space, etc., etc. "Plug and Play" is what we're looking for.
JOURDAN,
The antenna junction box is located behind the drivers seat inside the same plastic panel where the seatbelt retractor is. The unit is powered up by the radio on/off so tieing the 12v positive there should be easy. Just attach the ground to the same ground lead as the junction box, and you should be up in no time.
How do you get in there? Pull up the door sill cover, straight up then back. Then pull the interior panel toward the center console and it should pop away giving you enough access to make your connections.
I'd consider mounting the FM MOD box under the carpet behind the drivers seat on the angled slope (not on the floor) rather than inside that panel for two reasons 1) access, 2) to avoid proximity to the retractor assembly - safety. Velcro should do it. Then run your input to the center console area where you'll be able to keep the NOMAD out of sight and power-adapted via the 12v access. plug.
PLEASE LET ME KNOW HOW THE JVC SOUNDS!!!! It's the unit i would have bought from Crutchfield. Hey, great minds think alike.
JOURDAN,
