S
sothpaw
What do you guys think about this mod
on the LT1/LT4? Assuming that the stock
pressure is within the acceptable range
(?37-45 psi), will upping it give you better
performance?
What's the fuel economy effect? If the pressure
is always higher, would you use more fuel
at idle and cruising (1400 rpm for me)? I would
think so.
Do ya think the stock or hypertech chip would simply
compensate by decreasing the injector open time so that the fuel/ air
mixture is same (no hp gain in this case) at WOT?
Has anyone actually done this one on an LT1/4 and
seen good results? If so, was this a stock car?
performance?
think so.
