Adjusting convertable top on 2000 vette
Tigershark_11
Smokey..
2000 pewter convertable 6m
Does anyone know how to adjust the rag top? If the drivers door closes the window doesnt go under the black piece on the rag top. window needs to be down a little then if you shut the door and put the window up its ok.
You should take off the interior door trim, than you can adjust the glass so that it closed properly.
Is there a bolt that you adjust to move the glass up and down once you remove the interior door trim?
Thanks!
