Advise for installing replacement convertible top
  • Thread starter Thread starter renlaf
R
renlaf
Hi ! Everyone
Anybody had install a replacement convertible top ?
I order one that is already cut and sew and want to install it myself.
Is somebody experienced the job and is there a few points I should be more cautious about ?
Welcome good amateur advise
René
Rene,
I see your Corvette is an '87. Did you mean to post this thread in the C5 forum, or the C4? ;shrug
Post in here and let me know if you would like this thread moved to the C4 General Discussion forum.
:w
-Patrick
convertible top
Patrick said:
Rene,
:w
-Patrick
Hello Patric
I figure that on c5 or c4 the technic was the same. So maybe that more people could read. I also done the post on the c4.Maybe i am not allowed to do on both. If so i won't do again.
Thanks Patrick
René
Hi, Rene,
I honestly don't know how similar the convertible top replacement procedures are between a C4 and C5. My Z06, of course, has no removeable roof portion.
There's no problem with posting this message in both forums- I guess I should have checked the C4 forums first. I just wanted to confirm if the C5 Forum was indeed the forum you had intended to post your question in. No harm done.
:w
-Patrick
thanks
Patrick said:
Hi, Rene,
:w
-Patrick
Thanks Patrick for your answer.
Like you, I don't know about what difference, can be on c5 and c4 on convertible top installation.
Maybe some guys know about and will let me know some points that are basic on both.
By the way, congratulation, you are doing a fine job of supervising and helping. Keep on the good job.
René
Patrick said:
Hi, Rene,
:w
-Patrick
I had a 96 LT4 convertible and now have a 2000 convertible. The tops are very different, secure differently and the top's framing is different. The C5 does not snap the rear into the toneau to secure it like the C4 does, the C5 top only secures on the front windshield frame. The C5 top is raised to a verticle position and then opens like the letter V. When the front is secured to windshield frame, the rear seals by a downard pressure generated by the tops framework as it is opened.
