EricVonHa
I thought I'd share this in hopes of seeing if anyone else has seen how their door skins are attached. I had to remove my driver's side panel because the belt-line always had a little "bulge" to it. The most difficult thing in removing the door skin was the removal of the door panel and then also removing most of the hardware that holds the aluminum insert inside the door (the stamped piece that holds the interior door handle, etc)
Well, it looks like the repair is a success and just required that one of the fasteners be re-epoxied to the fiberglass.
What I was curious about is how, if at all, your aerobody door skins are sealed to the original door. On mine there was a gasket like insulator at the front and rear vertical edges of the door. The bottom was wide open.. presumably for water drainage.
Here are some pics:
Here are some pics:
