The Plastic Lizard
I bored the tb to 2". Did all the other crossfire hacks for more air and fuel pressure.
now when I try to balance tb, I cannot get idle lower than 975 in gear.
the rear tb is sitting on the stop (set screw not engaged) and the plate is still not 90deg to the bore. I can get the front plate to close 90 deg.
so I don't know if there is a vacuum leak or if something is screwed up. I tried the old propane trick, but haven't found a leak yet.
advice appreciated.
advice appreciated.
