Subfixer
Ok, Purists look the other way.....
For those of you out there with add-on A/C, I have a question that could not be answered by any of the "Big Three" aftermarket A/C companies' tech folks.
I've got a 327/365 set up with all the factory deep groove pulleys, 65 L79 power steering pulley. Alt on the Pass side.
Everything lines up just the way GM designed it for a 65 L79 with P/S.
It seems that the 3 A/C add-on companies all use the same compressor mount for installing the compressor on the driver's side (made by the same subcontractor). The problem is that that mount is set up for the 300 hp pulleys which are quite different than the 350/365 setup. None of these companies knew there was more than one option for pulleys on a small block Corvette.
So I'm going out to you guys who have managed to keep your original deep groove pulley setup and installed an aftermarket A/C system. How did you do the belts?
I want to get this answered in my head before I buy something that I have to rig up to make work.
Thanks.
Thanks.
