kmacpher
I’m working on my ’81 red vette for fall/winter.
Driving season ended prematurely with Torsional damper debacle (aka: harmonic balancer not) went off about month ago, engine still started and ran, but that darn thing was making a pinging noise and I read many bad things about crank shaft damage are associated with not having this key component working properly. At the time I thought I threw a rod or lifter, so a $50 hunk of metal from AutoZone seems cheap. (Do I need a fancy torsional damper for more power or extra coolness?) Started the process of replacing. Whilst there, I’m contemplating removal of the air conditioning system, removal was always a thought but never a real threat to actual occur until now because it seem too much like work, not enough like fun driving.
Why remove AC, I’m thinking removes critical mass, did not work anyway, and I live in Ohio, whereby higher speeds and airflow are my conditioning (one more reason to push the speed). Less draw on engine another reason to remove. Should I remove the condenser cooler (radiator thing in front of the engine radiator) while I have the whole front torn apart? Does front radiator core and assemble provide strength to body or protection for the engine radiator?
The factory shop manual says to “remove the hood from the car,” to remove condenser, is the hood a pain in the ass to put back on afterwards? Of course it is. I ****ed away a weekend replacing the fuel filter. I guess that I’m looking for Caveats in this action.
Can anyone provide reasons NOT to remove factory air? Resale or value reduced because missing? – of course I’ll keep the parts in a box somewhere in the garage, with the idea that I’ll put them back on if I resale.
Is there severe danger to bodily hard on the a/c gases, which I doubt are there anyway?
NOTE: While there I’m replacing the old radiator which was literally “glued” together to make it through the rest of summer, again, broken radiator driving in summer, welcome to Ohio and a gallon of water. Is the weight reduction of the aluminum radiator worth the $500 price tag?
Many questions, one posting.
Regards
Regards
