Philip Jones
The air-conditioning/heat climate temperature control has apparently lost calibration. The driver's side has a noticable difference in temperature from that of the passenger's side. Probably 5 to 10 degrees difference (warmer). I have tried restarting thinking it would reset, but it did not solve the problem. The problem started when I replaced a weak battery but did correct itself after several starts. The problem resurfaced when I changed the temperature (warmer) driver's side and later turned the temperature back to the coldest setting. Is this a calibration problem that the dealer can correct or does it require a new or remanufactured climated control. The passenger's side works perfect. The other climate control fuctions work properly. Any advice would be appreciated.
