Air doesnt work
  • Thread starter Thread starter Maverick402
M
Maverick402
One day the air in my 81 decided to stop working. I checked the switch with a tester and found there was no power going to the switch. I checked all of the fuses and theyre good. Anybody know whats goin on?
if you checked the switch at the compressor,check the relay,make sure you didn't lose a ground somewhere,check your wiring as best you can to make sure a wire didn't break,or corrode on you,check to make sure you have power at the console switches
good luck ...bill:w
I only checked the switch in the console and there was no power there. Where is there a relay?
i show an a/c blower motor relay on the fire wall towards the passenger side
of the anti-theft hood switch.
good luck,bill...:w
