corvettecrazy said:
thats sweet, but how did you do it?
Well, let's see, I bought the cone from the "Home Deput" for about.... hmm...$15.00 bucks..some where around there.
I measured the length that I needed from throttlebody to air filter housing, and added i little more in length, just in case I end up a little short.
Make sure that you measure the width of the outside diameter of the throttlebody and the air filter housing before you start, a little big will be fine but to small you'll end up starting all over.
Split the cone in half, and this is where the measuring part comes into play.
Get the 2 ends and reform a "cone" each end has to be the same measurments as the to devises that it's going to cover. (throttlebody & air filter housing) addjust till you have the correct measurement's, mark where the cone over lay's.
Now your going to need some fence wire, or something like that, small gage, it doesnt have to be big, and with it you pretty much sew/stitch up the two ends where you marked at, before doing so, get some heat resistent silicone and put some on up the length of the cone then over lap the 2 ends and sew it up.
Now, after that, your going to need something that is stiff, yet flexible, like the...heck, let me just show you......
This band that I'm pointing at is what I used to stablize the inside of the cone so it wont callapse under strong vacum.
I cut the one end off that has the addjustable screw, so it'll be just the metal band itself, I connected them together inside the center of the cone, and also stitched it in, I'm sure you might have a better way to do this, but thats how I did it.
After doing the stitching of the cone and metal band thats inside of it, use a little more of the silicon where the wire goes in and out of the cone to keep it air tight. (no air leak's)
I suggest that you make this at night or when you dont plan on driving the car for a few hours to make cutain that the silicon is dry.
If you have any more question's on how to make this, just ask and I'll try my best to answer them.
I hope that this was enough info for you to make one of your own, I hear that these cones are now sold in different colors now.
