Thanks guys. You just reafirmed what I was afraid the problem might be. Whale, I haven't checked to see if the hose is leaking or if its the booster itself. The idle is affected by the air leak. But I can hear the air only when the brake pedal is pushed down. Pedal feel seems ok. But, then again if this has been ongoing and I never knew it, I don't have anything to compare to. The pedal feels fine. Edmond, I'd like to know how good these aftermarket boosters are. Since this car is mainly used for autocross, I don't want to sacrifice performance for cost. Now I'm thinking that this booster thing is probably what has been causing my braking problems that I had posted earlier in another thread. During the past racing event under hard braking, I had been experiencing momentary wheel lock-up before the ABS kicked in. Could be a related issue.
