jbonifas
I am sure this has been discussed many times, but I will bring it up again because I can't find the answer. 1981 obvioiusly I need to find someone locally that has expertise in Corvettes, but, I didn't. The guy at Goodyear seemed to know what he was doing. The car was pulling to the right. He adjusted everything he said he could and it made it somewhat better. The problem he said was that he needed to take another shim out, but there were no more to take out. My simple mind thinks, why not just put a few back in to balance thing out. Anyway, what is the deal. If you look at the upper control arms:
# shims on Left side at the front is "0" and back is "5"
# shims on Right side at the front is "0" and back "1". He says sometimes if you replace the bushings etc, you may get it better. Does this mean anything to anyone and if so, where to I go! :confused :confused
