alignment update
  • Thread starter Thread starter ro.co2
R
ro.co2
I had the alignment shop redo my alignment I'll post the old and new numbers and will welcome any feed back.
old
camber 0.9* 0.7*
castor 1.0* 1.5*
toe .11* 0.10*
rear left rear right
camber 0.0* 0.1*
toe 0.04* 0.01*
new
front
left right​
camber 0.1* 0.0*​
castor 2.3* 2.4*​
toe 0.05* 0.06*​
rear
left right
camber -0.3* -0.4*
toe 0.06* 0.05*
The new numbers have helped my high speed steering and the returnability of the wheel but I'm getting a pull to the right at high speed whats up?
Caster and camber numbers look OK, but toe-in at both ends is excessive; should be 1/32" (.015*) at each corner, and it's about four times that (.05*-.06*, which is 1/8" per side, or total toe-in of 1/4"). Those are max permissible toe-in specs for the old bias-ply tires.
Thanks for the reply john. Dealing with this place has been pretty hard I may just go to someone else. I'm getting ready to get out of town before we see what ivan does, I'm more afraid of being without power again than the storm ,so Ill let you know what happens when I get back. Thanks again.
