coreysteffel
I have a 2003 Z06. A few months back I got the "service column lock" messages, added the part to fix that issue and the car ran fine. I drive the car 2-3 times a month if this matters. The other day went to start the car and all HELL breaks loose, got service active handling and reduced engine power. Charged the battery over night, no help. Disconnected battery cables, charged over night and the car cranked, moved it 60' then same issue. Took the battery out and replaced it, car cranked then same thing. I unhooked battery cables, help them together for 20 seconds to do a reset, car cranked then all over again after sitting for a little while. I have unhooked anything that would be draining the battery, tested battery when car was down and when it was running and is showing the same output. Seems like it will sit for an hour or so then go to hell. I have made sure no dampness was at the passengers side floor board that might cause issues. I am up for trying anything at this point. Thanks in advance
I pulled all the codes today and here is the list: 1000, 1064, 1176, 1160. They are Loss of communication undetermined, LOC w/ BCM, LOC w/RFA and LOC w/LDCM. Anyone have any clues at all ?? This is killing me
