napacruzerC5
Went on a 75 miles drive today and checked the tire pressures about 10 miles into my drive. Pressures read 28 all around which is about 2lbs lower than my dial gauge read a couple of days ago. After about 50 freeway miles checked again (I check often since I run non-runflat Kumho MXs and want early warning if I'm loosing pressure) and they all read XXX. I few miles from my desitination I checked again and still XXX all around. All other gauges seemed to be working fine so the problem had to be the sensors. I parked the car at my destination and then on my way home checked it again a few miles into my drive home and they still all read XXX. Checked again nearer to home and no change. Sensors are orginal mounted on OEM wheels (3rd set of tires) with 45k on the 2001 Coupe with an in service date of Sept 2000. Could the sensors all decide to die today? Or is it an ECM or other sensor reader problem?
