D
davethepackerfan
Guys,
Back to work on my project 81. The next thing I'm attacking are the brakes. The pedal goes all the way to the floor easily, and then stops poorly when I crush it in the floor. The car pulls to the right significantly when I do stop.
The power brake booster does not have anything hooked up to the grommet on the front. From reading through some old posts, I know there should be a check valve there, and then a vacuum line to the back of the carb. So I bought a check valve and some 3/8 line. Does this hook up to the hard line/tube coming off of the back of the carb? Any suggestions? Thanks,
Dave
Dave
