BLACK MOON
I'm currently running an alternator with the external regulator. I'm going to upgrade to a bigger alternator. My question is should i use an external regulator or convert to an internal regulator. Suggestions?
BLACK MOON said:I'm currently running an alternator with the external regulator. I'm going to upgrade to a bigger alternator. My question is should i use an external regulator or convert to an internal regulator. Suggestions?
BLACK MOON said:It all sounds like greek to me. Now I'm more confused.
IH2LOSE said:On my 67 deville I am running alot of stereo equiptment in it,I chose to convert to an internally regulated alternator from an ambulance (120 amps)because I wanted to install a high output alternator for the car and I was also in the midst of a bit of rewirieng for the stereo system.
The rebuilder who found and sold me my new alternator explained he would have been able to rebuild the excisting alternator I had to a higher output that could have handled the load no problem.
If I had to do it all again I would have just had mine rebuilt to stronger specs.
BLACK MOON said:What did you do with the externally mounted regulator> Just disconnect it or was significant rewiring needed?
IH2LOSE said:The wireing to convert was simple.its pretty much a adding some jumpers in the excisting regulator and leaving it in place. But the wireing to carry the addtional current was not so simple.
also on the caddy I had a ton of work to rewire so the idiot light was still able to work some what properly. Right now on my caddy when I have a CD playing with a lot of bass and the sub is hitting hard my "Gen" light is flashing with each hard hit of the sub. Unless your adding a high end stero (whitch I dont see would fit in our cars) I would suggest having Ken Bruno motor sports out of up state new york building you a high out put exsternally regulater alternator
Why do you want high out put internally regulated
BLACK MOON said:I am adding a stereo, amplifiers and for my MSD. I was told this would help all get truer voltage.
magicv8 said:I got a $70 135amp replacement alternator from alterstart and it plugged in.
