A1Avette79
I am having some problems with the battery/starter/alt system. When I stop my 79 (L48, automatic w/air) for a quick stop (like at a gas station) it has a hard time restarting. Starts fine if I make a long stop, say at least an hour. It never grinds as if flooded or vapor lock - just the initial sound of the starter kicking in then silence. Sometimes if I stop for a a little longer it will start but the starter will engage then hesitate for a second - then start up. I had to call my new best friends at AAA 3 times so far. While I was waiting after about 45 minutes I tried the car and it started. I turned it off and tried to restart it but no go. When hooked up to the AAA booster it started immediately with no hesitation. Each time I took my battery (Optima Red Top, a little over a yr old) to the local auto parts store and had it charged up over night. It took a charge and checked out as "good". After being back in the car for about a week (about 5 - 6 starts a day) it would all happen again.
I found a short in the "clock, dome light, cig lighter" circuit. Pulled out the fuse and the short is gone. I put in a new battery thinking that maybe over time the short had killed the battery. I also took the alternator to a alternator shop to have it bench tested - came out good. I called the starter manufacturer (PowerMaster) and the tech said it sounded like sometimes the starter isn't getting enough power from the battery.
I ordered a new set of battery cables which I'll install whenever they arrive. I also wanted to check the grounds in the system. I can see where the battery neg ground attaches to the frame. Where is the alternator ground. I can see the black ground wire from the alternator join up to the wire loom on the firewall. Where does it go from there?
