M
maxm
At idle the DIC schows 12,8 volts. If i test with a voltmeeter on the battery it schows 14,8 volts. SO....Everything is OK with the charging but on its way to the DIC i loose 2 volts.
Is there a way to adjust the readings on the DIC. It is not a big thing but i would like the DIC to schow the right voltage.
Max
Max
