One wire goes to the horn relay and the other goes to the starter. Look at the wiring diagram for the routing of each wire. Find the horn relay and you will see a black wire with a white tracer (B/W), that's one of them. Find the starter and you will see a solid black wire going to the solenoid, that's the other one. That circuit runs through your ammeter.
