C
corvettegreg
I am helping a friend who has a 1970 coupe, 350-300 HP. His car would always smoke at startup. It burns clean for the first 15-20 seconds til things start to warm up, then smokes (blue) for a couple minutes until the choke kicks off, then is fine while you drive it. It sounded like typical valve seals so we borrowed the tools and changed them. The car already had umbrella seals so this isn't the first time she has been worked on (and a couple were pretty brittle). We replaced with vitron seals that go over the guide boss on the head, but do not require machining.
Well, after all that she still smokes. Since it always happens when you first start up and the heat riser is closed it always smoked on the driver side only and I wanted to try to narrow down where the problem is. I wrapped some wire around the heat riser to hold it open but now when we start the car it never smokes! If I release the riser she smokes again...almost like oil is somehow getting into the crossover passage in the intake.
Has anyone ever seen this situation? My next thought is to pull the intake but am hoping someone can enlighten me on what may be going on.
