vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
[h=2][/h] A few weeks ago I bought a full ABS module from Craig's list ( $100.00 ) the guy seems like a straight shooter..
He had an 03 that got rear ended and there were no codes PRIOR to that time.
I swapped his ECBM in and I had the EXACT SAME issues! But it did free my original ECBM up to ship out for repair.
Brandon ( ABS FIXER ) did the $ 150 repair AND I had him do the anti surge mod ( $50.00 ) .
Brandon stated he could not get mine to fail on his test rig, but did see my code.
Plus mine was right on the edge of failing ( cold solder / heat stressed pieces ) ...
3 days ago I got my ECBM back from ABS Fixer and Brandon is quite a help !
I have a 1243 code (came with the car ) ...
2 days ago we did water pump, stat N hoses PLUS blew out all the junk in front of the radiator.
While we had that all torn down we replaced the ECBM.OH BTW we changed out the T15 torx bolts for allen's IMHO easier to work with.
BUT the new ECBM did not clear my code... and again was doing the EXACT SAME THING !
Brandon mentioned that if you do not have FULL POWER to the ABS pump motor, he has heard of secondary electrical issues ( bad power lines & connections ) ...
SO the plot thickens.. Today, I changed out my ignition switch assy ( new GM electrical & AC Delco lock cylinder ) .
You can pop the green clam shell off the back of the electrical part of the switch,and inspect the different internal sections of the switch.
Mine didn't look good & and I had to replace the ket switch anyway to repair the REMOVE KEY IN RUN " feature ". So I was hoping that I was getting a mild current limit in the switch....
Prior to this I would start the car ( keeping my foot on the brake, which keeps the ABS from going into self test ) ...
Let the voltage come up on the dash gauge ( which LIES ) .. I have a digital gauge in the cig lighter which is RIGHT across the battery.
Dash gauge ~ 13 volts cig lighter gauge 14.2 volts.
The SECOND I lift my foot off the brake, both voltage gauges dip ( 12.9 across the battery ) I hear the blower motor speed SLIGHTLY reduce...
( 1 Mississippi ) BAM the ABS And traction control lights come on ! Voltage comes back up, and everything is NORMAL.... Well except for the nagging DIC !
So replacing the switch did NOTHING to help my ABS issue...
I had my son put his hand on the ABS pump and he states he can feel it running, for that 1 Mississippi period of time.
So trying for another step forward in solving this.I was looking at different code scanners to activate the ABS and do advance testing ( Like the TECH 2 but I don't want a CHINA CLONE ) ... I realized I had another ABS pump in the garage !!!
I understand that my ABS pump assy may be just gooed up with old brake fluid...
I have read other post's all over the NET that you have to heat up a GREEN WIRE ( wherever that may be ) to force the ABS pump to spin up.
My brake fluid ( when I got the car ) wasn't BLACK but it wasn't pretty & the car has spent most of it's life in florida.
And I have bled all 4 corners so the fluid is CLEAR along with dumping as much as I could from the Rez 2X ( small syringe and aquaruim tubing ) .
So I had another idea.....
So I made an adaptor to hook DIRECTLY to the ABS pump . You remove the 2 pin connector on the bottom of the ECBM multi pin connector.
Take 2 spade lugs ( male ) and cut em in 1/2, so they are 1/2 the width of the spade.... Hooked it up to a 12 volt battery ( with an amp meter ) ....
and 6.7 amps start up leveling back to ~4.5 amp on a DRY ABS pump....
Armed with this information I will try this in the car tomorrow and continue the saga...
I currently do not have a FSM for the 02 and I would KILL for the ABS wiring diagrams...
SO I'm here... more to follow...
Mike
Mike
