I'm with you on that Stallion! I just try to take it one step at a time, and remember that I'm a part of this hobby because I enjoy it!
I must admit however, when you start to take something apart for a project, and find another 2 things that are broken or "Bubba'd" in the past, the amount of work ahead can get overwhelming and discouraging. Here's the breakdown on my '70:
TO DO:
Interior - (About 60% done)
I've bead blasted, installed new springs, painted and covered one seat. I'm waiting on the metal parts from the chrome shop to finish it up
New carpet's partially installed
I have all the components ready for a completely hidden CD/MP3 sound system, it just needs installed
I have most of the major components that need re-dyed ready to go.
Brakes - (75% done)
I rebuilt a leaky caliper, and changed all the front lines. I just have to get my new rotors measured for runout and installed.
Bushings
While installing the brakes, I've found some bushings that are in dire need of replacement.
Carburetor
My '70 has a 650cfm Holley on it, that leaks to boot. I'm installing a Holley 800cfm double pumper that my dad had laying around and donated to the cause
, since it's a lot closer in spec to the stock QuadraJet. Plus, there's some sloppy fuel line work that I'll fix also.
Universals
I have a noticeable "clunk" sound when shifting gears, especially drive to reverse. This most likely seems to be the culprit.
Tires
I currently have the same BF Goodrich Radial T/As that the previous owner installed in 1984. They look like new, but they're too old.
Vacuum System
One headlight doesn't go down well, and the wipers smash into the wiper door before it's fully opened.
Battery
Dies if the door's open for a few minutes. An easy fix.
Sorry if I went on and on there, but at least I got myself all organized here! I hope to get mine back on the road for at least some of the summer. My winter project list definitely expanded and extended into the summer season!
Best of luck with your list,
Vince
