toobroketoretire
Banned
The battery in my '82 will go so dead in a week the clock won't even work.  I have my 6 amp trickle charger on it (with the ground cable disconnected) and I noticed it's only charging a low 2-1/4 amps when dead batteries normally charge a full 6 amps.  The battery is only 1-1/2 years old but it could be defective.  I was having a problem with my courtesy light timer as it wasn't turning the lights off; only dimming them.  So I replaced the delay module but that didn't help the situation at all so the problem is elsewhere.  As long as it's started every few days it starts okay but after one week it'll be down to 3 volts; indicating a drain somewhere.
Can any of you think of a common source of a battery drain in the later C3's?
