grumpyvette
I got asked if anodes are a good idea?
IF you pull your intake and find its starting to corroad badly in the coolant ports, or your aluminum heads are ,well,
thats far more comon on BOATS, especially those used in salt water or where the battery grounds attached to an intake bolt, but in cars its usually a sign of a BAD ENGINE GROUND and LACK of a RADIATOR ANODE, and running water vs ANTIFREEZE COOLANT in the radiator. BTW, A BAD GROUND can also cause the pilot bearing on a manual trans to show damage IF both the trans and engine are not grounded to the frame and the battery to the same frame
heres an old post
well, when you run an aluminum performance cylinder head on an iron engine block with pure copper head gaskets, and aluminum radiator ,like Ive been doing for many years, those anodes are mandatory, and yes they do work
sup: and prevent or at least slow electrolysis a great deal
naturally youll need to use the anodes in the block vs the radiator with a plastic radiator like some cars have
http://www.flex-a-lite.com/auto/html/anode.html
http://www.bmcno.org/RadCap.htm
http://www.jcwhitney.com/autoparts/...10101&sku=anode&searchbtn.x=16&searchbtn.y=12
IDEALLY theres ZERO MEASURABLE voltage! and with both a decent frame to engine ground and battery to frame ground theres seldom much voltage in the coolant, but having a transmission to frame ground in addition is a good idea as Ive seen that help also, a loose ground causes lots of flaky/intermitent problems
Determining the levels of EME present in the cooling system is very easy. All you really need is an ultrasensitive voltmeter. Simply remove the radiator cap, stick the positive probe into the cooling system, and ground the negative probe to the radiator. With the metal dialed down to the lowest voltage setting, take a reading of the total amount of electrical volts present in the cooling system. The reading should be somewhere BELOW 0.01 volts, if its not you NEED to find out where the grounds loose or an extra grounds needed and add an anode
running low anti-freeze concentrations like nearly all water,hurts the engine also, especially if its not distillede like from a hose where its got a higher mineral content so it conducts current better
MAGNETS
btw, add a few magnets to the oil pan and drain back area in your engine, the trap and hold metalic dust that comes from wear and increase engine life span by preventing that crap embedding in the bearings
http://www.kjmagnetics.com/proddetai...d=D66SH&cat=13
http://www.kjmagnetics.com/proddetail.asp?prod=D66SH
http://www.kjmagnetics.com/proddetail.asp?prod=D82SH
these are even more tollerant of temp swings and retain strength at even higher engine oil temps plus they are smaller and easier to use
The SH material in the D66SH magnets, means that the magnets can be heated to 300° F without any loss of magnetic strength, unlike standard neodymium magnets that begin to lose strength at 175° F. Suitable for many high temperature applications.
heres an old post
MAGNETS
:eyerole your joking ....and probably confusing the hell out of the new guys, ......as Im sure your aware the magnets tend to limit damage,or potential damage simply because they tend to trap and hold fine metalic dust,like from lifter or rings wearing, now it should be obvious that most of the crud that finds its way inside an engine is not necessarily magnetic like bits of dirt,sealants,moisture, varnish etc. but there are times when those magnets are a huge plus,
