Rookie Vette owner
I'm still working on converting my 73 to a 427 and trying to find all the obstacles that are out there. The latest that I heard yesterday, was that there is a difference in the front frame crossmember where the harmonic balancer will hit if you are working with a "small block" frame. I had already heard that I could not use generic big block pulleys, but this is the first about a difference in the frames. I thought all the frames were basically the same except for improvements made through the years 68-82.;help
