do a 'Search'
Always great advice to search first!
I just bought a cooling fan switch from MidAmerica for 13 bucks, but my fan is thusly controlled. PN609-106 for '84-91, states an ON @ 200; OF @ 185.
http://www.madvet.com/
The 1990 and later years also need a conversion harness.
Hayden makes fans with adjustable temperature switches (Pep Boys, summit, etc.). I think of these as nearly the last resort, after cleaning debris, down-adjusting switching temps and ensuring the cooling system is in good shape. I am not a fan (no pun) of the manual switch. I wired one as a temporary measure and treat it as an abnormal requirement; not routine modus operendi.
After I evaluate this newer switch, (yes, the connector is not flat) I will add more fans as necessary for this 406. It should not be required for either of us.
<Added later> The fan comes on at 192 and switches off at 180 or so. I need more time to fully evaluate this, but I think the 'running start' on the heat issue that the cooling fan gets, will much improve the cooling situation on this 550hp 406. Also, daytime will be a truer test, when OAT is higher.
From MidAmerica instruction sheet:
The fan switch is between cylinders 6 and 8 (passenger side) for 1984 and early '85 cars. After that any fan switch is between cyls 1 and 3.
The enclosed sheets do a fine job of describing where to install any switch you might purchase. I don't need the keyboard practice to echo it. Besides, I have found this the least expensive source for the PROPER switch.
Mike
