82mystery
need help on unhooking electrical on fuel pump at the pump .i don't know if this pulls off or what and i hoped not to break the connection off. the ground seems to brazed in place but i tried to gently pull the hot wire off to no prevail, please help if possible, i am going to install a 85 pump in its place. this the connection that is located on plate where you put gas in. thanks larry
