Subfixer
Seems everytime I fix one thing, I get another problem.
Here's today's mystery.. A beautiful day, low 70's. I replaced the fan clutch yesterday, and let the car idle for an hour in the driveway so I could watch the temperature. Stayed right at 180* the whole time. Verified with an IR gun. Took a one hour leasurely ride on the back roads to see how everything would perform on the road.
When I first started out, the car idled fine at 800 rpm. About 20 minutes into the cruise, the idle started to drop. At steady throttle in 4th gear between 1000 and 1500 rpm the car was starting to "buck" a bit. As I kept cruising, it got steadily worse.
I thought it was loading up, so I did a couple of blasts to 6500 rpm with no breaking up or any other problem, so it seems the ignition system is working correctly. By the time I got home, the car was barely idling at 550 rpm. It seemed to be running really rich. Engine temp never got above 185*, so I know it's not a coolant overheating issue.
Checked the timing, 10* BTDC, Dwell 30. No fuel leakage observed, but that may not mean anything.
Both float levels appeared to be correct when I pulled the sight plugs, but I knocked both front and rear float levels down about 1/2 turn each, but haven't made another run yet. Hoping that will fix it.
Car is a '64 vert, running a "correct as GM built it" '64 327/365 setup with LT-1 cam. M20, 3.36 rear. "New" restored 2818 carb installed last month.
Any other ideas out there? Thanks.
