since everyone was so good at helping me understand horsepower vs torque...i have another question that has always confused me.......most cars have aprox a 5/16 fuel line from the tank to the engine...and i understand that pressure will vary at the carb or injectors,depending on the type of system/car you have...my race car is carburated and i just installed an expensive barry grant fuel system this week...they have me run #12 line from the tank to the pump /filter assembly...if you are familiar with the braided line system...that is absolutely HUGE!! then on the filter side to the regulator at the engine,they had me run #10 line....which is also very large line....then on the other side of the regulator they have me run #6 line from the regulator to both sides of the carb,which is like 5/16 or even a bit smaller......this is why i get confused......i understand in any fuel system you need both volume and pressure...you can only have so much pressure though or you will flood the needle and seat or injectors,thats why cars have a fuel pressure regulator...in my case this is about 7psi down the track...but as far as volume goes...no matter how big a pump and no matter how many gph it can crank out...your carb can only consume so much fuel...correct???.....so i guess my question is...if volume is so important...why do they have me go from huge line out of the tank...to medium line up to the front...then little tiny line to the carb??? doesent this defeat the purpose of the big lines in the back of the car?? and on top of that...only so much fuel can squeeze through the regulator correct?then, even if you could get a large amount of fuel to the carb inlet...the carb can only intake what it can utilize...right??.....maybe i am just confusing myself!!!
