Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
Ordered a set of SS brake lines from Classic Tube.. Nice people. I said... Heh I want to convert to a dual MC can you bend the lines in SS to 1965 spec and make it so they are 2 seperate lines directly to the MC?
I want the brake line on the rear on top of the frame to match up with the mounting points. Sure no problem....They Said
Not what I got. They sent me a brass front split block with 1 in 2 out for the front lines. Only problem is the threaded holes in the mounting Block are larger then the front line brake fittings. (See Pic's)
The rear line seems to be a 67 as it only lays on the inside of the frame. I also have a bunch of straight lines that I have no clue what to do with. Maybe they are the lines that go to the MC.....Oh.....I guess I have to bend them to fit...!!!!!! Ahhhhhh..didn't I pay for that?
The rear framecrossover line is not secured yet but does look like it will have to be bent up from the center.
Also..look at my driver side frame rear kick up and note that there are two holes side by side where a brake clip held the rear feed line and the crossover line to the passeger side of the car. I wasn't there when these lines were pulled and was told that it was the first time they had seen a clip secureing the two lines together. The AIM does not show this clip...OK
OK John Z Your On....Whats The Deal with this clip thing.
So you guys that have converted to Dual MC ..... Whats the deal here? How did you connect your STOCK rear line to the MC? And I guess you had to change the fornt split block.
Isn't there a kit that comes with the MC and the rest of the gack?
I might just send this kit back and order a sraight up 65 kit and get the MC Conversion Kit ....
.......................................... Not A Happy Camper
http://www.geocities.com/daulquad/lines002.jpg
http://www.geocities.com/daulquad/lines003.jpg
http://www.geocities.com/daulquad/lines004.jpg
http://www.geocities.com/daulquad/lines005.jpg
http://www.geocities.com/daulquad/lines006.jpg
http://www.geocities.com/daulquad/lines007.jpg
![lines001.jpg](http://www.geocities.com/daulquad/lines001.jpg)
